1 - 3 of 3 Posts
My Jeep Patriot started to have rust at the rear fender (both sides). I searched in the internet if I can buy a rear fender but no luck. I went here to ask if I can buy and change the rear fender? Or it needs to be re-painted (that can be expensive?) Thanks so much in advance.
Use the SEARCH feature
The rear would require repair to the quarter panel.
Often that means cutting off the bad steel, and welding on a replacement section.
Or you can try to bondo it.
I just had my right rear fender rust repaired and re-paited. He cut out the rust spot and welded in a new piece of steel and finished with bondo and paint. Total was $400.00 USD. Two and a half day turn around. Looks like factory new. tom.
1 - 3 of 3 Posts
