1 - 3 of 3 Posts
Hey everyone,
I recently replaced my 2016 Jeep Patriot air filter with this WIX filter: https://www.oreillyauto.com/detail/...4/v/a/130121/automotive-suv-2015-jeep-patriot
Everything went fine, but a couple days later I started getting a rattling noise. I re-did everything and the noise only went away for a day or so.
I also noticed that the 10mm bolt on the air box cap, which holds the bracket connecting to the shock tower, is spinning/stripped. This specific part here:
94139
94140
Would anyone know whether it might be due to the stripped bolt, or if I should replace the filter again with OEM or K&N?
Thanks in advance!
It's doubtful that the air filter itself would cause a rattle, since it's a pretty soft item. It's most likely that stripped bolt.
Discussion Starter · #3 ·
Ah good point, I appreciate the input. I’ll see if I could get it out and replace it. If you have any other solutions I am all ears. Thanks!!
1 - 3 of 3 Posts
