thanks moparado,
it leak pretty bad. the morning of the leak dash lights were going off. everything was flashing. this happen about 2 weeks ago. i did dry everything out. i pulled radio and re seated wiring. the sunroof still works. just lost the a/c and radio. i will look into this TIPM. dont know much about that. i believe if i have to replace the radio i will with a aftermarket. the factory one used is over $500.
The Total Integrated Power Module (TIPM) controls just about everything electrical from power; locks, wipers, windows, door locks, ignition, etc. including the AC clutch & likely the AC controls. Probably the radio controls also.
The TIPM is typically located inside the fuse box unit in the engine compartment. Its a complex computer which uses a sensitive data bus system and integrated relays to control and power various electrical functions on the vehicle.
Its possible the water contamination corrupted the computer data bus system software.
This is a long shot, you might try re-setting the PCM and hopefully TIPM too by:
a. Remove ignition key
b. Remove the negative cable from battery.
c. Remove the positive cable from battery
d. Keep the cables away from the battery-
(IMPORTANT) then hold them together for 10 minutes (there might be some sparking as power is drained from the module circuitry.
e. After 10 minutes, reconnect the positive cable then the negative cable.
Also if any water got into the instrument cluster, that also could of corrupted the PCM/TIPM software.
The AC control knob switches/connectors and radio might still be water logged.
If the reset doesn't work and if you've got the time and know how pull the dash bezels and inspect the switches/connectors and radio.
