Per the 2015 owners manual, the 2.0L is limited to 1000 lbs gross trailer weight / 150 lbs tongue weight, whether you have the oil cooler or not.
The amount of weight put on the trailer hitch.Also, what is tongue weight?
Correct.Ok so with the tongue weight limit being 150lbs - I would NOT be able to use the above mentioned motorcycle hitch carrier since my bike alone weights 450lbs, right?
I was going to disagree. However, looking at the photo OP posted, you're correct. In the first post I thought Spade was loading this onto a trailer like I do with my lawn equipment. Agreed, no way on a carrier!Correct.
Open the hood and look for the CVT fluid filler tube cap:Is there an easy way to determine whether I have the CVT or not?
@Spade , a word of caution on using the sixth digit, it isn't always accurate for years 2014+.Sixth character is a P so no go for CVT. I will be getting the transmission fluid replaced just to be safe!
