Have you experienced water leaks?
  • No leaks - nice & dry inside
    Votes: 715 59.7%
  • Firewall leak
    Votes: 26 2.2%
  • Sunroof leak
    Votes: 186 15.5%
  • Roof leak other than sunroof
    Votes: 149 12.4%
  • Side doors leak
    Votes: 31 2.6%
  • Rear hatch leak
    Votes: 128 10.7%
  • Other
    Votes: 67 5.6%
  • Total voters
    1,198
1 - 20 of 577 Posts
Well I got the front dome light leak. What's the cause of this? Sunroof?
POTM June 08
Mine is dry as a bone...
Discussion Starter #6
If you're not sure, just check the 'roof leak other than sunroof' selection.
My hope is that all owners here will respond so we can get a reasonable cross section of the Patriot population. If the numbers are significant, I will do what I can to get this info to Nardelli's office. I think he would be very interested in the responses (both good and bad) when they number in the thousands.
Plus, I want to help nip this problem in the bud, if it really is a problem.
Thanks for this survey, I think it will be very helpful to see where the problems are and also see the percentage ratio. My lil guy is dry and I keep it outside. We have a one car garage and my wife's Camry has the place of honor, but my Jeep is tough and actually likes it out there!
Mine had been going strong for 6 months and then... the dome light filled up with water and dumped it all over the center stack. :(
Uh oh. I don't like the sound of THAT!
My rear cargo light leaked. Dealership seems to think they found the issue - something with a plug or cup? The paperwork is at home, and I am far, far away. :) They wound up pulling down my headliner and cleaning it for me, and pulling the water out of the cargo carpet.
My Jeep has spent the last week and a half sitting outside at my loal airport - with a tupperware container strategically placed, just in case. Hopefully they did fix it. :)
The first use of my sunroof was after a heavy rain. I opened it, put the car in reverse, stepped on the go pedal and was rewarded with a cold shower. I was very concerned having read of similar problems in this forum. I could not find anything wrong with the car and concluded it was standing water on the roof which would not have been a problem had I backed out of the driveway prior to opening the sunroof. This was June '07 and has not happened since so I checked "No leaks" in the poll.
No leaks in mine. I have a 2007 sport w/o the sunroof and I park mine outdoors at night, in a parking garage while at work M-F during the day.
Just experienced a leak this morning. This is the 2nd time I'll have my Patriot back to the dealer for the leaking sunroof issue.
Aftermarket sunroof = no leaks.
Haven't noticed anything else.
Although I park under a carport, only have 2500 miles and we are experiencing a drought.
I do use the laser car wash, and have been dry on the other end of it.
I am very suprised and saddened at the # who are having problems.
This must be the 'flappen hood' of 2008.
Now we just need a youtube video.
What did they say was wrong with it the first time, and what did they do to (not?) fix it?
No leaks...had it since April/07...FDII...I did get the sirus radio w/mine...I didn't know if there is a wire that goes from this antennae through the roof, following the headliner to the front of the Jeep and into the radio…Any chance this has a bad seal on some of these?
Discussion Starter #19
The poll suggests that about 1 out of 10 owner get water seepage of some kind. That sounds high, but there are only 63 votes so far. We need a few hundred more votes to get a more accurate picture.
My Patriot goes in for the day tomorrow so hopefully I'll find something out as to why my Patriot started leaking after 6 months of being perfectly fine...
1 - 20 of 577 Posts
