81 - 100 of 111 Posts
In my unsuccessful attempts to use the service manual links in this thread, I continued searching until I found a couple of links in a Dodge Caliber forum, "Caliberforumz". There is a sticky there, ">>>> Caliber Service Manual Download<<<<" I initially downloaded the first link, but after further investigation, the root of the web address is a strange foreign site, so I moved on to the second. Open the PDF via "2007 DODGE Caliber Service Manual" link and simply save it to your computer.
I can't post my URL finding until my 5th posting.
So here are the links:
This is the forum page link:
http://www.caliberforumz.com/showthread.php?26500-gt-gt-gt-gt-Caliber-Service-Manual-Download-lt-lt-lt-lt
This is the link to the second post within which directs you to a page with service manuals for other vehicles as well, if interested:
http://www.biodsl.com/durangofsm.htm
Here is the direct link to the 2007 Caliber Service Manual:
http://www.biodsl.com/fsm/2007DodgeCaliberSM.pdf
Hope this helps!
To anyone that has had a hard time trying to get the service manual working. I discovered a program called IEtester. This IEtester will emulate IE5- IE8 Link is here:
http://www.my-debugbar.com/wiki/IETester/HomePage
With IEtester all you need to do is select new IE6 tab.
Then type in the path to the default file and it works great for me. This is much easier than trying to hunt down IE6 and get it working for 64bit OS. I hope it helps others.
Great find! I can confirm this works brilliantly.
I am looking for some wiring diagrams ,and have tried several times to download the service manual and actually open it up but am still not succesfull .I have the manual burnt onto a disc ,but have no idea how to get it open so it can be used .I even have the debugger listed above ,but getting nothing with the manual .I am not a computer pro ,any suggestions would be greatly appreciated .
the service manual comes with the patriot , yeah?
I think svg viewer, which is the program to view wiring diagrams, only works in Windows XP. You can either build or buy a cheap XP PC or use a virtual box like Oracle to run XP in a Win 7 or 8 window.
Thank you ,I will try to get an xps computer running .In the meantime ,I was able to get a caliber manual downloaded and viewable ,hoping the wiring is fairly close .
So I know this is an old thread but after some digging for a manual for my 2010 jeep patriot i found this thread. I downloaded and used a virtual iso reader to open the file and could not get further then a list of category's of parts. After reading user post i learned it was only good on windows xp so thought i was screwed. However i did more digging and found a program that can still use this file and access everything within it. Its called ietester which can be downloaded at http://ietester.en.softonic.com/ . After you download and install open the car guide like you normally would in your normal internet explorer then copy the address in the address bar. THen open ietester and select ie8 tab and paste the address there and viola you can access everything. Hope this helps someone who was having issues
K so I downloaded the link in todde702's post #44, I changed the compatibility settings so it would open the categories and the service info portion works flawlessly for me now. But the wiring diagrams will only open up the categories and not the diagrams themselves. Can anyone help me out with this?
