1 - 4 of 4 Posts
2007 Patriot. Passenger high-and-low beam do not come on anymore, driver's side works normally. Both passenger and driver side headlights come off a single fuse, so there is power going there. My passenger side front turn signal is also sometimes not working, sometimes fine. I have replaced the bulbs, so I am thinking it is a loss of continuity in the ground wire, which is likely common to both the headlamp and the turn signal. But I don't know which wire is the ground. Is there a color code?
There are several ground wires bundled together and crimped into one ring lug (G110) so the best thing to do is cut the ring lug off, strip the wires, and put new ring lugs on all the ground wires rather than trying to fix just the one.
92381
92382
92380
92378
92379
Thank you! I don't fully understand the ground distribution diagrams, but Fig. 3 and above seem like enough to find and fix this. I had no idea where to start. I appreciate your time and patience!
1 - 4 of 4 Posts
