1 - 6 of 6 Posts
There is a huge lack of traffic in this area. Anyone from Portland here?
Stear clear of the Camas area. Folks here drive at least 5mph UNDER the posted speed limit. :doh:
Portlander here...I recently got a 2012 FDII and I just ordered the RRO lift kit. I'm looking for a good place to get it installed. DeadInMe, did you do it yourself? Know of a good shop around Portland?
Any advice would be appreciated!
I had Hiway Fuel in Washougal do mine a few years ago. One thing they encountered while re-aligning was that the control arms (I think that's the right part) have to be removed everytime you need to re-adjust the camber. they said they had to put them on and take them off about a buhzillion times to get it right.
other than that, all turned out fine. I took a measurement with a tape to the ground from the fender before and after the job. Strangest thing is I only yeilded 1.5 inches of clearance. I'd suggest you try the same thing and see if you experience that.
1 - 6 of 6 Posts
