1 - 20 of 43 Posts
Not Sponsored
Have a question about a strange noise your patriot is making? Wondering what size tires fit? Below will be all these questions and answers we are trying to help owners get to the bottom of without searching through thousands of dead threads and provide WELL ANSWERED responses.
Please keep the arguments out of this thread, this is JUST for questions and answers. If you have a question that would fit good hear, please feel free to post it and once answered it will be added to the list.
Let's get started!
General Questions:
Q: How do I upload pictures to a post?
A: The easiest way is to create an account on photobucket, imgur, or flickr and upload pictures to it. They will provide you a link to copy and paste into the thread using the img tags, or press the "link image" and paste the link.
Q: I am experiencing a squeaking sound coming from the front of my patriot when I go over bumps, what could it be?
A: Check the front ball joints, the stock ball joints are a faulty point and tend to go out every 40,000 miles. Most users replace with a MOOG replacement part, and have much longer life. Heckler made a great write up on replacing the ball joints, HERE.
Q: What's the biggest size tire I can run STOCK?
A: 225/65/17 if you have the factory 17s, or 225/70/16 if you have the factory 16 are the biggest sizes you can go without any rub on suspension, and the wheel arches without any lift kit, or spacers.
Q: Where do I buy hood louvers for my patriot?
A: Rocky Road Outfitters currently sells hood louvers for our patriots, and pictures can be found in RossoRacer's build thread around page 12.
Q: How do I change my oil by myself?
A: Check out these tips on changing your oil, as well as directions HERE.
Q: How do I change my spark plugs by myself?
A: Check out these step by step directions on changing the sparkplugs HERE.
Q: How do I change my cabin air filter?
A: Check out these step by step directions with pictures for the cabin air filter, behind the glove box HERE.
Lifting Questions:
Q: What lift kits are available for purchasing?
A: Current 2 main lifts are offered for our patriots STU's Coil lift (2" spring lift) and RRO's spacer lift (2 1/8" spacer lift.
Q: What's the biggest size tire I can run WITH a lift on stock wheels?
A: Max lifted tire on stock rims with 1.25" spacer is 245/65-17 - without spacer we recommend not going wider than 225 due to the new suspension geometry with the lift.
Q: How do I go about doing the pinch weld mod my patriot?
A: Take a box cutter, cut off the plastic hump from the wheel well plastic, then take a good hammer and proceed to hit until pinch has been folded over. Optional: spray paint the pinch weld once folded to avoid any rusting spots from developing.
Q: I saw people with skidplates for offroading, where can I read about the installation process?
A: In this thread, you can see the discussion leading up to the install, and part numbers. The install begins around page 8 if you don't want to read through. Click here for the thread
Q: Do I need camber adjustment arms after lifting?
A: Various answers have been given for this question, but the general consensus is to purchase them for safe measures. Without the arms you run a risk of being unable to properly obtain an alignment which will lead to premature wear on the tires.
Q: Do I need an alignment after lifting my patriot?
A: YES, YES, YES. You need an alignment after any adjustment of the suspension.
Q: Do 15" rims fit? Will any from older Jeeps (XJ, TJ, etc.) work?
A: Yes! Quite a few do, check out these two topics for some more detailed information. HERE and HERE.
Q: Is there a way to add sway bar quick disconnects?
A: Of course! It's a jeep, so HERE you go!
Lowering Questions:
Q: How do I lower my patriot?
A: Currently, the easiest way to achieve about 2" of drop would be H&R's H&R's for sale at Tunerdepot. They can be found else where, just a place to start. Or, you can purchase a coilover setup for the Dodge Caliber SRT4 and spend some time making that work.
Q: Do I need camber adjustment arms after lowering?
A: YES. Without the arms you run a risk of being unable to properly obtain an alignment which will lead to premature wear on the tires. Our stock patriots do not handle lowering well, and camber arms should be purchased.
Q: Do I need an alignment after lowering my patriot?
Q: How can I get my patriot as low as Creation?
A: Creation is lowered on a set of custom modified BC coilovers and universal bags, adjustable camber arms, and lots of cutting and bending. If this doesn't sound fun for you, I'd suggest staying away. Creation made a response to his FAQ's in his build thread to address specific questions he gets often, Click here to find out.
Q: How do I bag my patriot?
A: Air Suspension Installation - Creation - Jeep Patriot Forums
Without a lift the max tire size is 225/65R17 if you want no rub at full lock.
Unsponsored Baja racer
Those who want a ride as cool as mine....it's not possible. There is no such thing. :p Louvers were ordered from Rocky Road, then installed by the local body shop at a total cost of $270 for installation. Price of louvers depends on shipping cost to individual location. I personally run a Midland 1001z CB radio, though Cobra has one or two models of similar size. Go much bigger, and it'll be a little crowded in a Patriot. Trumpets from a Wolo musical air horn can be easily secured to the engine cover if you predrill the right size hole, just make sure to leave room for the oil fill hole. "Front plate install kit" or whatever the dealership calls it(for pre-2011 models) is just two specially-made license plate screws to put a vanity plate, or front license plate as required, on the front bumper. For those who want to install a magnet-mount CB antenna, the two best locations are at the front of the roof ridges, or the top of the liftgate, centered either way. Keep in mind though, if you could be going into a low-clearance situation, best to put the antenna up front so it can be knocked over. If put on top of the liftgate, there's less extra wire and the antenna would be more likely to just break. Either way, might wanna keep a bottle of touch-up paint handy. "It's a Jeep Thing...You wouldn't understand" stickers and other fun items can be gotten from www.allthingsjeep.com. Or at least that's where I got mine.
Not Sponsored
Discussion Starter #6
I added the RRO louvers to the Q/A's. CB's are questionable, as it comes down to preference so I'd prefer not to add them since everyone's opinion is different.
Not Sponsored
Discussion Starter #8
Biggest size tires that fit a 16" rim? I know it's here somewhere
How to change oil, and sparkplugs. Again I know it's here somewhere
There all here somewhere, I've spent a majority of the morning digging through threads so I stopped for a break to do some homework. This list should be pretty big when it's "finished" I'll make sure I address both suggestions.
Max lifted tire on stock rims with 1.25" spacer is 245/65-17 - without spacer or after market rim I wouldn't go wider than 225 as the wheel is pulled closer to the strut with the lift installed.
alignment is recommended at a place that does work and alignments often on lifted vehicles. Most places just use factory #'s, which are no good after a lift is installed.
Not Sponsored
Discussion Starter #12
Added all of this information! Thanks for the help guys.
https://imgur.com/ is a great place to put pictures as well.
Feel free to delete afterwards. The biggest 16" tire without mods and no rub is 225/70/16.
Yeah, was just mentioning that anything much bigger than a 1001Z can make it crowded. You'd wanna consider the size of the unit, type of antenna and mounting location for both.
Google+ pictures is handy.
to post a open the one you want in the G+ viewer, then right click on the image and copy the url
you get something like: "https://lh4.googleusercontent.com/-tsALVe5PNeM/VEaWCmVVIeI/AAAAAAAAc5E/rNVdvFO8jJM/w936-h551-no/Capture.PNG"
change the numbers after /w and /h
/w640 is the max width before the site will resize them. If you don't know the aspect ratio just put 0 for height
click the insert image button and paste in the url as: "https://lh4.googleusercontent.com/-tsALVe5PNeM/VEaWCmVVIeI/AAAAAAAAc5E/rNVdvFO8jJM/w640-h0-no/Capture.PNG"
Then highlight all that and insert a web url as "https://lh4.googleusercontent.com/-tsALVe5PNeM/VEaWCmVVIeI/AAAAAAAAc5E/rNVdvFO8jJM/w0-h0-no/Capture.PNG"
then people can click on your picture if they want a full size image.
Also for youtube videos you just have to click the YouTube button then insert the characters after "https://www.youtube.com/watch?v=" such as "R_a-bY8MonA"
I can just copy/paste the entire youtube link straight to a thread without the button, and it'll show the video.
1 - 20 of 43 Posts
