Hey all, I have a 2016 Jeep Patriot Sport 2.0 CVT, and I want to get a Bluetooth OBD2 dongle.
The main thing I want to do is create extra keys with JScan because I only have one and don’t want to pay $200 at the dealership. But, I would also like to change tire size because my stock tires are 205’s and I have 235’s which are about 1.7” larger in diameter. Another thing I’d like but isn’t necessary is constant connection to use with an app like Torque to get real-time info, but I have concerns about battery drainage.
I searched the forum and found some relevant info, but not a lot.
Ok, so first off, does anybody have a recommendation for a good budget scanner? I just want something tried and tested that works to do the JScan mods I want. I’m considering a VeePeak mini just because it’s $12 on Amazon and I mainly just want the JScan stuff done. Long term reliability isn’t absolutely necessary, but I always prefer long lasting quality, I don’t like creating unnecessary e-waste.
Second question: Has anybody successfully changed tire size with JScan? There was somebody from a 2021 post that said they had major errors when they tried, but I’ve seen a YouTube video where they mentioned they changed the tire size with Jscan and didn’t mention any issues. Maybe it was user error or JScan has been updated since?
Third question: Is the OBD2 on the Patriot constantly connected to power? And if so, is there a low power module you recommend? I’d like to use Torque, but I’m concerned about battery drain if I leave it plugged in. I’ve considered getting an UltraGauge module for real time info, but since I’m already buying a Bluetooth OBD2 module for JScan, might make more sense to just use Torque.
Any help is appreciated!
