1 - 5 of 5 Posts
2015 Jeep Patroit
2016 Patriot:
The radio turns on, changes stations, but all of a sudden no sound. plays cd's with sound. Checked fuse and restarted system. Still no results. Any solution.
If it's just the radio with no sound check the antenna it's connections.
If those are good it may be a problem inside the radio; solder joint, component failure, etc. and you may need to replace it.
Perhaps someone else can chime in with more info/suggestions.
2014 Jeep Patriot, North Ed.
Does the volume on the display increase when you turn the volume dial? If not, than the radio is shot (like mine was). If yes, then I'm not sure
1 - 5 of 5 Posts
