1 - 2 of 2 Posts
If they both went out at the same time the switch may have failed.
Try using the "flash to pass" switch (pulling the switch level toward you) and see if that works.
Video below explains it.
You can try checking for output with a meter at the bulb socket, and check for broken wires.
Rectangle Slope Font Parallel Diagram
1 - 2 of 2 Posts
