1 - 3 of 3 Posts
I'm replacing the trailing arm, the control arms and the toe link and I can't find a few specs. This is on the rear of a 2012 Patriot front wheel drive with rear drum brakes.
What are the torque #s for the 4 bolts that hold the wheel bearing to the trailing arm?
What are the torque specs for the toe link (I found the number 26 ft/lbs - but that seems really low). Are both those toe link numbers the same?
Thanks in advance!
1 - 3 of 3 Posts
