21 - 40 of 69 Posts
They are replacement parts for a 2011 4wd patriot...so i guess it would be about the same as pre2011 FDII.
I'm not sure if someone ever compared pre2011 FDII springs to 2011+ springs.
From Moog catalogue :
part #81490 (Front) is for either 2007-2008 Patriot & compass 4WD or 2011 Patriot & compass FWD (CVT...std trans got a different part number)
part #81480 (front) for 2011 latitude x is .5 taller than other 2011 4wd springs.
Does latitude X model have something different..like something heavier in the front?:confused:
I don't see any moog part number for 2007-2008 fdII so we cant compare specs...
My father got a 2014 patriot 4wd, i'll try to compare height vs mine.
Congrats M7T for your info and your new Patriot looking
May be #8140 coils are for the Patriot with 6AT transmission, SIX-SPEED AUTOMATIC 6F24 POWERTECH WITH AUTO STICK, I think it is the heavier one, so I could read, here I leave some information about it:
http://www.auto-brochures.com/jeep.html
PATRIOT 2011
Capacities/Weights/TOWING (pounds unless otherwise specified)
Base Model Curb Weight 5-speed manual (2WD/4WD) 3,115/3,261 (1,482 KG)
CVT2 (2WD/4WD) 3,196/3,339 (1,518 KG)
Payload Capacity (includes occupants and cargo) 925
Maximum Gross Vehicle Weight Rating 4,575
Maximum Loaded Trailer Weight (when properly equipped) 2,000
PATRIOT 2007
http://www.autoevolution.com/cars/jeep-patriot-2007.html#aeng_jeep-patriot-2007-20-16v-fwd-mt-159-hp
4X4 2.4 2007 5MT
WEIGHT SPECIFICATIONS
UNLADEN WEIGHT 3199 lbs OR 1451 kg
4X4 2.4 2007 6AT
UNLADEN WEIGHT 3359 lbs OR 1524 kg
4X4 2.4 CVT
UNLADEN WEIGHT 3346 lbs OR 1518 kgG
4X4 2.4 CVTL
4X4 2.0 CRD 6MT
UNLADEN WEIGHT 3340 lbs OR 1515 kgGROSS WEIGHT LIMIT4409.2 lbs OR 2000 kg
COMPASS
2007 4X4 2.0 CRD 4WD MANUAL
DIMENSIONS SPECIFICATIONS
LENGTH173.22 in OR 4400 mmWIDTH71.25 in OR 1810 mmHEIGHT64.17 in OR 1630 mmFRONT/REAR TRACK59.84/59.84 in OR 1,520/1,520 mmWHEELBASE103.93 in OR 2640 mmGROUND CLEARANCE8 in OR 203 mmCARGO VOLUME11.8 cuFT OR 334 LCD-
UNLADEN WEIGHT 3395 lbs OR 1540 kgGROSS WEIGHT LIMIT4409 lbs OR 2000 kg
The european Compass CRD 4x4, mine, is a little bit heavier 3395 lbs, thinking about moog coils will fit... instead of STU coils...
Regards.
Hi, i did not install camber bolts but they had to slot the strut holes a little to get the camber right when they did the aligment.
What do you mean by slot the strut holes? Is this something that any alignment shop would know how to do? If you don't mind me asking how much did you spend getting the springs installed totall with alignment?
Thanks man.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Discussion Starter · #35 ·
Thanks man.
They drilled the holes (where the struts attached to the knuckle) to an oval shape so they can have a little camber adjustement.
I installed the springs myself.
Gotcha thanks man!
How hard was it to install them?
There is a great Sticky I just read on here on installing Stu's coils. The process should be identical. I can't post the link here because I am new to the forum and this is my 1st post. :p It is a few threads down from this one in the Suspension and Tires section.
I am currently debating on
RRO
STU or
This MOOG method.
I currently have a 2007 Limited. How is this set-up still treating you today? It looks like you installed this in October 2015? I also would probably get camber bolts if I go this route.
Thank you for all this information!
Here is my moog lifted rig!
Nice!!!!
Really thinking about getting a set of these just to boost my rear because of all my stereo weight...
21 - 40 of 69 Posts
