Is there a filter that should be replaced when changing the manual transmission fluid?
Thank you.
Thank you.
About 2.5 - 3 quarts, give or take.How much fluid does it require?
Thank you sir. 1 other question--can I use Valvoline or do I need the mopar brand?About 2.5 - 3 quarts, give or take.
According to Valvoline, their ATF+4 fluid is approved and officially licensed by Chrysler for all ATF+4 applications, so yes you can use it.Thank you sir. 1 other question--can I use Valvoline or do I need the mopar brand?
Does it need to be specifically for manual trans or does the automatic suffice. The reason I ask is that the Valvoline bottle says for automatic trans.According to Valvoline, their ATF+4 fluid is approved and officially licensed by Chrysler for all ATF+4 applications, so yes you can use it.
