This morning while driving to work the malfunction indicator light came suddenly on [number 26 in the manual - it's the engine image].
What did I wrong?I was driving a bit longer in the 4th gear with rpm over 3 300,I mean I just searched for my mobile and didn't upshift to 5th.I know this definitely shouldn't cause this light to come on but it did it.I looked in the manual and on the net and the advice I'm reading is to drive and see if the light will come off eventualy.Appareantly if all is fine the light should come off on its own after few driving cycles.I read about Jeep TJ suffering seriously of this problem and they say that after about 40 start ups it goes away on its own in majority of cases.
Yes,I checked the gas cap and I added fresh Esso fuel {I always put Esso in ,I don't trust the smaller independent gas stations].
Basically what I wish to ask you is this, has anyone of you suffered the same problem and how did you fix it?
Thanks.
Yes,the car runs 100% ,I didn't detect any aiks or pains,the engine sounds well,it has lots of power,there is no change in the performance with this light staying on.
Thanks a lot.
Thanks.
Thanks a lot.
