21 - 24 of 24 Posts
Discussion Starter #21
Looked for oil leak under Jeep after it sat two days. No Leak. No play or sound when pushing tires down. The brakes look a little rusty. Don't know if I should go to dealer garage or go have brakes fixed first.
Flesz, when you check the cv axle for play, make sure there is no load on it. Like if you were parked on an incline. I’m going through the same problem in trying to isolate a road noise. My driveway has the slightest incline. I lay down and ,right hand, sort of roll the car , by the wheel, forward to take the load off the axle/transmission and the other hand check the axle.
Discussion Starter #23
well took it in today and told two bad wheel bearings and brakes are worn down....I knew I needed to replace the brakes...just gonna be big $...
Next time we can help talk you through doing these yourself and you can same $$. Glad you will be noise free and rolling smoothly soon enough.
21 - 24 of 24 Posts
