1 - 10 of 10 Posts
Jeep Patriot License Plate LEDs
(Cherokee used for comparison)
License plate bulbs are used to illuminate the rear license plate on your Jeep Patriot. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to Diode Dynamics' LEDs, you can easily add this luxury look to your Patriot!
The installation is 100% plug-and-play, just replace your Patriot's factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Patriot looks at night.
Brightness:
Diode Dynamics offers several LED model options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
*HP3/HP5 are available in warm white, 4000K, 5000K, 6000K Cool White Color temperatures
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Jeep Patriot).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: License Plate LEDs for 2007-2017 Jeep Patriot (pair)
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, Email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Bulb lifespan?
I ordered these plate LEDs several months ago, but I've noticed that one has burned out already. Is there an expected minimum lifespan of these bulbs? They have worked great up until now and it's a shame because I've been looking at purchasing other bulbs for directionals, etc.
Thanks!
Thanks!
Hello,
We are terribly sorry to hear you are experiencing any issues. Please give us a call or email us: [email protected] & (314) 205-3033
The bulbs are backed with a 3-year limited warranty.
Thanks,
Nick C.
Hello,
Thanks,
Nick C.
Just called, Justin set me up with a replacement.
Thanks very much!
Have a great holiday
- G
Discussion Starter #10
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
1 - 10 of 10 Posts
