1 - 20 of 105 Posts
Went out to my car about 15 minutes ago to head to lunch and as I pulled away, a nice steady stream of water came pouring out of my sunroof controls/front dome light. Water poured all over the dash, radio, and seats!
Needless to say I called the dealer within minutes and it will be going back there this evening. Whatever the problem is, they better fx it and anything that the pooling water may have damaged! :(
That's not good. It's been raining here, I was thinking about checking the seals around the windows for leaks. Anyways, I hope they get it fixed.
the only thing I can think of is is that the channels for the sunroof are clogged. But I dont know what they can be clogged with. There's no trees anywhere near where I park and it certainly hasn't seen very much dirt in the past month!
that sucks! hope they fix everything fast and well!
We had a couple of three inch rains here and I had the same problem. I brought it to the dealer and they dropped the headliner and tested it. My body guy said that it leaked so bad the drains could not keep up. They have ordered a new glass and seal section, but there are none avaliable right now. I believe that ours are not the only ones having trouble.
P.S. I have had power moon roofs in every car I owned and this is the first to pee on me...
:puke:
I sure hope I dont have to start researching Lemon Laws...
:eek: I am feeling awful queasy after reading this. I just ordered mine yesterday with a sunroof... I hope this isn't a widespread problem.....
I'm wondering if they got a bad bunch of seals???
I am sorry to hear that Gaze. My dad has been a mechanic for over 25 years and works for GM. First thing he told me, "Don't get it with sunroof". Damm glad to listen to old pop. I hope all is fixed for you Gaze.
Mine's kinda drippy too. Haven't been leaked on, but I remembered reading some stuff here about leaks, so I stuck my hand up in there when driving around in the rain. Came back out wet. Felt like it was sweating more than leaking, but there was still water coming through.
Happens on the Liberty's also. The drain tubes get kinked or sometimes the tubes aren't even hooke up. Then if it rains the water just pools in the head liner until you start moving.
With my Compass, it's only happened to me once, and that was when I went through this really powerful Esso carwash, still though, it's not supposed to leak at all. It hasn't been leaking in the rain. I think the pressure from the carwash moved the glass slightly and water got in, it was leaking droplets through the back, nowhere near the controls..... I'll have to get it fixed before winter though, that's for sure!
At least I'm not the only one, let me know what Chrysler does.
:pha ha
I had the same problem with TWO 90 Subaru Legacys. I swore off sunroofs after that. I'm sorry you're having that problem and I hope they can cure it, but I will NEVER get a sun roof from any maker again.
Mine leaks droplets too in high pressure car washes. Only when the roof gets sprayed directly from above.
However, I've driven through a torrential rain storm and didn't get a single droplet.
My aftermarket sunroof holds drip dry tight. Since I busted my knee I have only been able to use the laser wash and no sign of leakage or during rain...
Sorry Gaze... one of those posts you would rather not here... :eek:
Jim
1 - 20 of 105 Posts
