I replaced the cluster in my '14 a few years back. When I first started the vehicle after, I got a lot of warning lights and a lot of odd codes (such as fuel pump #2 codes) and the gauge readings were way off. I thought I would have to put the old cluster back in. However, the next time I started the vehicle everything was normal. Apparently it programmed itself. I did have to use AppCar DiagFCA to turn on the new features that the replacement cluster had, such as EVIC and enhanced TPMS. May not be the same experience since yours is an '07.
If you do swap out your cluster, note your mileage before you remove it, since the odometer of the new cluster will be different.
