141 - 145 of 145 Posts
Happy to help. Also I would note that a mine used a torx (r) 30 bit on the Coil.
Also an m6*1.0 x 20mm is a good replacement, when you loose a Coil bolt. I messed up and sheered the connector nipple off of Coil. A zip tie is holding it on. If you shear off the Coil nipple, the red connector CPA won't seat. You can override it with a dentalpick. I secured it with a zip tie.
My gaps had .054, ". The new ones are gapped at. 044.
Sent from my SM-N910V using Tapatalk
Thanks a lot for these guide
I just changed the sparks last saturday and with just 24000 miles they were very beat up. My patriot has the same power as brand new!!! It was very simple. However, I believe that I did something wrong. When I turn the ignition off it makes a tic tic tic noise for a couple of seconds. While running is ok and no rattle at all. Any clues or pointers?
Thanks in advance for your help.
Thanks to the original poster and all that have added information. Used this for the second time on my 2014 with 91k.
I have the same noise when my wife's is turned off. Does it sound like 3 short "click" sounds one can make with their tongue and cheak?
Sent from my SM-N950U using Tapatalk
