1 - 2 of 2 Posts
I have a 2010 Jeep Patriot 4x4 the horn goes off periodically I changed the fuse because the last one was blown now I just heard it go off and it did it once before since I've changed the fuse it's a fuse keeps blowing would that be a wiring issue or something else? Thank you for anything you can give me here
The fuse blows because the power draw on that circuit is too high. You either have a short or an incorrect fuse. Your owners manual should have a layout of the fuse box. I would make sure that you are using the correct rated fuse because you go down the short circuit road.
1 - 2 of 2 Posts
