1 - 6 of 6 Posts
I may go to a shop tomorrow
anyone know what it could be?
does it need to go on a rack to look at this?
brother paid 600 some dollars for his. Could just say screw it but I drive a good ten hours a week and best to keep it maintained
Moderator
Heat quit . . . Not quite sure what that means.
If the fan isn't working it could just be the switch. That's what it was in mine.
If there is no heat it could be that your radiator is low.
I have no idea what it was but it started working again
I had an appointment at place I got work done last time and canceled it. so relieved
If no air comes out of any vent then it's probably a fuse or blower motor. If it blows, but it's only blowing cold air, it could be a number of things. The blend door could be stuck in the cold position, you could be low on coolant, the heater core could be plugged, or could be a bad thermostat.
If it started working again, it's not the fuse, but could still be one of the other things.
Discussion Starter #5
yes it was low on coolant
Reactions: Ignatz
1 - 6 of 6 Posts
