I cannot seem to find a list of possible colors for a factory headliner replacement. Is there only the one white headliner available?
The reason I ask is my headliner is going to be replaced after it had a repair attempt go horribly wrong. For the full story, check out my STOLEN thread, and this is one of the many things that was to be repaired.
There was a small burn in the liner, right above the driver window. After a botched repair that the repair shop sub-let out for $180, here is the current state of my headliner:
As you can see, there is now a yellow substance inside the hole, and the liner is stained from whatever chemical they used on it. There is also a secondary, lighter stain that encompasses quite an area.
The repair shop IS going to replace the whole liner. So I thought:
"Does it have to be white? Are there other, less easily soiled, colours available?"
But, alas, I cannot find any info on this subject. So, does anyone out there in Riotland know?
