1 - 2 of 2 Posts
So I started up my 2011 Jeep Patriot with my key button while not in car. This wasn’t my first time doing it but this time everything seem fine until I realized while pulling off windshield wipers weren’t working and headlights were on and couldn’t be turn off or switch and blinkers couldn’t be used any answers guy
As I mentioned in my response to your other post, you can try disconnecting the battery cables wait 10 minutes, then reconnect and see if anything changes.
You could also try checking all the fuses.
If none of those things help, it may be a problem with the two ground connections under the hood, a switch problem, or a failing TIPM.
The grounds are fixed by cutting off the old ring lug, stripping the wires back, and adding new ring lugs.
1 - 2 of 2 Posts
