1 - 18 of 18 Posts
Anyone know where the Fuse Box for the Inside is??
I know most cars/trucks have it under the dash on driver side but looked there and a few other place it.. i havent seen it please help me out ppl.. thanks!!!
POTM Winner AUG. 09.
It should tell you In your owners handbook??? Oh hello & welcome --go to the Newbie Forum & introduce yourself---Cheers!
just an average Joe
Fuses are in engine compartment.
Next to the engine air filter housing, behind the battery, in front of the suspension strut tower.
Vehicle Car
Fuse Box (TIPM - Totally Integrated Power Module) with cover removed:
Refer to the Owner's Manual for description of fuses within the TIPM.
just an average Joe
This information is based on '07 wiring diagrams ('08 is the same except for tailights and possible some other).
I don't know whether it is still the same for '09 and '10.
I ran my rearview camera system off of the 12V power outlet. (indicated on wiring diagrams as Fuse 16)
PK/BK (Pink with Black Stripe) - FISO (Fused Ignition Switch Output) Run-ACC
BK/LG (Black with Light Green Stripe) - Ground
Click the picture to see my install thread.
If you don't have heated seats you could use the power lead in the connector below the driver seat.
Wiring connectors site
C305
PK/YL (Pink with Yellow Stripe) - FISO Run (indicated on wiring diagrams as Fuse 30)
BK/LB (Black with Light Blue Stripe) - Ground
Hi,
I have a jeep Patriot 2009, the back blinking lights to turn rigth and left doesn't work, I have checked the bulbs and that are correct, and I checked volt and measure 0 volt (when checked the taillights measure 12 volts). So I think is a fuse, but I don't understand the owner manual description to know wich one is the correct fuse.
Could you help me to know where is this fuse? or any other suggestion?
Thank you very much.
Sept 2009 POTM
JM3,
Fuse #3 is listed as "CHMSL Brake Switch Feed" in the manual. I believe that's the one you'd be looking for.
In this picture, it's the red 10A fuse at the far right of the image, 3rd from the bottom. From the bottom you have a blank large socket, then a blue 15A fuse, then this red 10A fuse.
The fuse box is under the hood in the top right. It's covered by a plastic top. I had a hell of a time finding it my self. I think I did find it in the owner's manual when I looked.
My dashboard light went out and so did my tail lights. But when I checked the fuse box in the hood, all of my fuses were in good condition. I have 2008 jeep patriot and pepboys told me that their is another fuse box on the inside by the driver seat. Is this true? And if not, what could the issue be?
I know of that one i was just wondering if there any fuses under the dash area ..
If there is, it's an aftermarket add-on...good luck!
Guys...just following on from this...I installed LED fog lights and even though all my lights work (low beam and fog lights) the dash light for the low beam won’t work. Does anybody know why this is and which fuse I need to change...if it is a blown fuse? Thanks.
1 - 18 of 18 Posts
