Sorry if this has been covered but I couldn't find it anywhere.
I have changed front wheel bearings a couple times so I thought I was pretty good at it. When I reassembled it, I couldn't get the splined end of the hub flush with the bearing in the knuckle. All the others had gone all the way down. Now the mounted wheel still wobbles a little.
This time, one of the bearings was REALLY bad. I thought I filed down the dings on the shoulder where I had to use the bearing splitter to get the race off. I wonder if this hub is too worn or damaged to fit properly, or if I just need to try larger press? I have used my 12-ton press on all previous, but I have access to a 20-ton.
Thanks.
Thanks.
