1 - 3 of 3 Posts
Hey everyone,
I have a question about wheel/tire fitment. Here in the next month or so I’ll be installing the rough country lift on my 16 riot and planning on getting a new wheel/tire setup as well. Plan right now is a soft 8 style wheel with 245 sized all terrains. What is getting me when looking at wheels is the offset. As I understand negative offset will not work. I hear of some folks using 0mm offset, some saying only 30mm works. I’m just looking for someone to simplify this for me lol. The wheels I’m looking at purchasing have either a 0mm or +13mm offset. Will these fit fine or will there be more to this?
Thank you in advance.
Look on the back on one of your rims, there should be some numbers with the size, width and offset. Punch those in along with the tire size. Then put in the new rim and tire numbers. If it shows the wheel staying within the same distance on the inside, it should fit fine without rubbing.
Hope this helps
Use this site
Wheel-Tire size comparer
1 - 3 of 3 Posts
