1 - 7 of 7 Posts
I have a 2008 Patriot which recently (today) has been having an issue with registering the appropriate outside temperature. It says it's 39 degrees out which it was last night, the last time I ran her, but currently it's closer to 70 degrees. Is there a way to reset this?
Thanks for the help!
Funny, I have a similar problem, however, I have found after a few minutes of driving and/or shutting off the vehicle the problem usually corrects itself.
The Custom Guy
Yup. I thought this was the same problem with mine, except it kind of is and kind of isnt. When I get into my Pat it says its 115 degrees. Give it a couple minutes and it goes way down....to 105. Yea its hot out here in the desert.
Sept 2009 POTM
I hear ya Mak. I've seen 115+ a couple of times already this year from leaving it sitting in the sun.
The thermometer does take a minute or two to get set after you first start the car. If its taking longer than that, you've got a problem. I don't think there is a specific reset for it, but maybe resetting the whole computer would work too?
I thought mine read low as compared to our town's "time & temp" display. The old Chev S10 was always right on and the wife's Toyota too. So, I crawled underneath the front bumper and found a large bug--some kind of butterfly--wrapped around the sensor. Cleaned that off, re-seated the connector and now it does read the temp coming out of the 80 degree garage into the 100+ degree driveway before I can get backed into the street. Now I call the city and have them re-calibrate their sign to MY PATRIOT!
The same situation with my 2007 Pat on two occasions over the past two years. After about ten minutes, the correct temperature showed up.
As an aside, I told the service rep at the dealership and she explained this was perfectly normal. She claimed it takes her car about 30 minutes to register the correct temperature. I asked for a courtesy ride home, which she arranged. The diver mentioned that even tough the service rep was a brunette, she really behaves like a "blonde". Nothing personal, my best friend and partner is a blonde.
You tread on very thin ice amigo...
1 - 7 of 7 Posts
