Hey guys,
I've been referring to this forum for a while now for info about my Pat. I finally decided to join as I felt I could help people with a problem I had.
The ESP, BAS, Traction Control, and 4WD! lights were lighted on my dash for a while, sometimes turning on and off in the beginning, now staying on constantly. I read some other threads on possible reasons and heard about the corroded wiring splice in the driver's side kick panel. I went looking and found that I also had a corroded splice. I've attached pictures to show people where the splice was located on my Pat (08), since I never came across any photos in other threads showing where it was. I simply detached the battery, cut out the corroded part, stripped new wire and soldered them together. Once the car was turned back on the lights were out and stayed out (4WD was not engaging with the lights on but now works fine).
On a side note, all the splices along the floor wires are covered with looks to be hockey tape? I'm not sure why they didn't just just electrical tape or heat-shrink wraps...
Anyway, I hope this helps people in the future.
