1 - 4 of 4 Posts
Drove my Patriot all day with no incidents. In fact it drove great as usual! Wen I got home
turned the engine off and then for some reason the entire electrical system went off! Tried to restart
to no avail. It was totally dead after being driven all day! Any clues
Hi, welcome to the forum!
What year is it?
How old is the battery?
Have you checked the battery voltage?
When's the last time the battery terminals were cleaned and / or checked to make sure they're tight?
If the battery and connections are good, perhaps you have corrosion on the main power relay pins or a broken wire in the relay box down by the drivers side headlight.
2017 Jeep Patriot 4x4
Hello and welcome to the Jeep group. Sorry, that you're having issues with your Jeep I am sure you will come up with a fix from the great people here on this site. :cool:
Sounds like what happened to me when I got to work a couple years ago. Turned out to be corroded relays in the relay box as Sandstone mentioned. Cost me about $300 to get it fixed at a shop.
1 - 4 of 4 Posts
