Is there any way to access the inner bolt for the drivers door lower hinge that bolts to the pillar? I can get at the front bolt no problem but the inner one is obstructed by the whole door check deal. Upper hinge is no problem at all. Previous owner had the whole door taken by the wind issue that Ive fixed but still need to do a small adjustment on the bottom hinge to make it close perfectly. Any special wrench that might get at that inner bolt? I dont want to have to remove the door (again).
