Hi all, I have a 2010 2.4lt auto Jeep Patriot. It is stalling and running very badly.... And getting worse.... Have read lots of posts describing the same issues here. None include an answer... I've done; plugs, two plug coils, fuel system cleaner and the fuel pump. Some posts have mentioned a possible connection to ECU/PCM. But no conclusion. Is this the source of our problems??? Do the companies offering pre programed (to your Vin) ECUs actually work? Thanks. G.
Thanks for the shout back: Lights up like a Christmas tree!! Engine, traction, Abs, 4wd warning....Only codes in the ECU were spark coils 2 and 3... Replaced those and all 4 spark plugs.... Also replaced fuel pump, as the filter is integral!! Damn it!! Often felt like fuel starvation.... Each item replaced makes it go ever so slightly better but still stalling and no power.... Now revs past 3000 again, which is nice.... But then stalls when you break!! I have order the ECU/PCM... I will report back once it's fitted! Keep your fingers crossed... It seems like to many issues just to be the throttle body to be honest.... Often seems slightly better when the engine is at full temp... But can still stall under breaks.... And so many warning lights with no codes!! I've done a reset a few times... Thx. G.
I’m in the same boat, 2014 2.4 6 speed just replaced the throttle body and spark plugs. Runs 100 times better but still stuttering a tiny bit in 6th gear.
Thinking about blowing out fuel lines before a strainer replacement
In a weeks time I replaced throttle body, spark plugs, crank position sensor, did a hard ecu reset. Have since driven about 100 miles with no stuttering/hesitation. Idle is really smooth also.
I’m not sure what did it but my issues are gone 🤞..
Update* tiny miss came back! Went ape **** bananas with my scanner reading all the live data I could think of and found a bad coil... swapped it out and smooth sailing so far
