1 - 7 of 7 Posts
· Registered
I am hoping someone can help me out with a couple questions.
I just finished replacing the rear subframe on my 09 and am wondering how important it is to preload the suspension when torquing everything down. If it is what is the procedure?
Next take a look at the pic and tell me if I am missing a cap and have a problem...(that on the top of the rear diff)
Thanks in advance!
Liquid Fluid Automotive lighting Automotive tire Gas
· Administrator
Preloading matters, it can ruin parts if you don't.
The service manual calls for putting in bolts, then lowering the vehicle so it's sitting on the wheels before tightening.
Organism Font Line Auto part Parallel
Looks like the rear differential vent, a rubber tube connects to it.
Automotive tire Jaw Tread Art Gas
· Registered
2008 Jeep Patriot Sport
That cap is probably the actual vent. I think only the fdii offroad models got the hose and higher vent. The cap should feel loose and wiggle a little. For preloading the suspension for torqueing the bolts I've always just jacked the suspension up until the body just comes off the jackstand. That's usually enough weight to avoid tearing the bushings.
· Registered
Discussion Starter · #7 ·
Thnaks for the reply.
I think you are correct because there is no evidence of a hose ever being there...the cap does seem to function properly as well
1 - 7 of 7 Posts
