I drove up into the mountains recently in my 2017 FWD Sport and while I was 10 miles deep in the dirt my ESC light came on and stayed on. The light went out when I restarted the engine but re-appeared the next day and the day after that until finally I saw a check engine light.
I’m wondering if the Patriot brake switch is a weak link…
…(mine is original with only 16K on it) which got me to wondering if we have a list of Patriot weak points by model year. I didn’t see anything in the knowledge base and it seems like this would be a good resource our Admins could refer newbies to. For example, I imagine the throttle body would be listed for all model years.
While up in the mountains I checked that the electrical connector was engaged with the switch and then had an auto parts store read the codes (P0571 & C1000). The store did not carry the switch and referred me to a dealer. I researched online and confirmed my cruise control was not working and surprisingly found I had brake lights in the accessory position and with the Jeep running. I tried to buy a new switch in the next town but no joy so I decided to make the long drive home.
I drove 100 miles without touching the brakes (used auto stick to control speed) and when I stopped for my usual restroom brake I found that the check engine light did not re-appear when I started the Jeep…I assume this is because the bad switch did not have a chance to throw an error for 100 miles. I then drove another 100 miles in the same way and eventually saw the ESC light again when I got to town and started using then brakes.
I made it home and bought a new switch but after tinkering with the original switch again…all the dash lights have remained dark so I’m just driving it to see what happens. I will eventually put in the Mopar replacement switch.
