I know there has been a lot of talk about this in other threads, but I just want to ask for some advice here.
so I have had a lot of creaking and clunking sounds coming from the front end of my pat, ( yes, there were multiple sounds going on) I got my front control arms replaced and that got rid of the creaking noises coming from bad bushings. But I still had the clunking sounds happening and did some research and decided to replace the sway bar end links. I took them off and saw that they were shot. So I put new ones on that had grease fittings on them. That did help quite a bit. But there is still a clunking sound over bumps and potholes. It sounds like it is coming from the front end on both sides.
So what I would like to know is if you think it is the sway bar bushings or the struts? If I push on the front end manually I don’t hear any sounds. And the clunking seems to happen on smaller bumps and potholes. The bushings seem older but don’t look that worn. The driver side one has a small crack in the rubber bushings itself, so I am planning on replacing them anyway, but wanted to know if it could also be the struts??
sorry this is so long. Thanks!
