1 - 7 of 7 Posts
I have a 2007 UK spec 2.0 CRD and I've been having some trouble with it starting. Various Google searches suggest it could be linked to an issue with the clutch position switch. I've found some info on the Wrangler which says you can bypass the switch by simply adding a fuse in position 20.
Does anyone know if there is a similar way of doing this for the Pat? I just want to see if this is the cause of my problems.
yes i know that. i always press Down the clutch when starting, but sometimes you want a quick start to get the car warm without jumping in and out of the car...
1 - 7 of 7 Posts
