1 - 3 of 3 Posts
2009 Jeep Patriot Limited 4x4 Manual
I don’t know if this will really be a build thread, but I expect to post pictures of the beautiful island of Oahu Hawaii with my patriot. Also I have had to do a little TLC to put it lightly to fix issues and catch up on maintenance. Expect to also see what I did to fix things that may be happening on your model as well.
So far I have fixed all the issues with my patriot. I changed the brake pads recently and replaced a tpms sensor that was bad. I blew out my front sunroof drain passages and fixed a nasty leak coming from the dome light. Got my air conditioning blowing cold after I replaced a faulty relay for the cooling fan. No more check engine lights until I slam on the gas or drive continuously around 100 miles. Slamming on the gas gives me the manifold stuck open code, and driving for a long time is the catalytic converter. I have a adapter for the secondary o2 sensor but need to put it on a lift to get that sucker off.
1 - 3 of 3 Posts
