Hey i've tried searching in the forums, and can't find anything on this topic, so hopefully its not a repeat.
I just purchased a 2009 Patriot...very basic package...in terms of audio, I just have the generic single disc with a auxiliary port (no nav, sirius, etc). I do have a separate XM SkyFi2 that I've had from car to car. I just plug the SkyFi2 into the Aux port, which is very convenient, however when I turn the car on, it starts up on Volume 19...which isn't necessarily blaring loud, but it is enough to scare the crap outta me from time to time.
In the manual, it just says to make sure your Aux item (iPod, or in my case XM) is set at a lower/higher volume when you turn on the car, but my XM SkyFi does not have a volume option.
Basically my question is: Can you lower the default volume for Aux? When you turn off the car on FM radio it comes back on at the same volume level you left it, but it is not the case for Aux, is there a way to change that or a way around it?
