1 - 5 of 5 Posts
I never see any water driping from this drain, dealer said they checked it but after 90 miles on a hot humid day I see nothing when I stop.
I have to check mine out, too.
My Buick will leave a puddle, and my old S-10 would look like a faucet running, but I've never noticed anything under the Patriot.
Apparently a lot, if not all Patriots have the AC drain hoses aligned in such a way that they actually drain into the front subframe, which can cause the subframe to rot out prematurely. If I didn't see a little water puddle under mine while it was sitting with the AC on, I'd check that first. I've heard of people addling an additional length of hose using a plastic barb fitting to keep the drain line out of the subframe.
Big puddles under my Patriot after a short 5 minute drive in summer with the AC on. I can watch the water dripping out like leaky faucet. I assume that’s normal?
My 2014 is an Aussie/international model. Not sure why that would make any difference though?
Yours is normal.
1 - 5 of 5 Posts
