I'm trying to change my fluid in a CVT tranny on my Pat. Everything I see online says there should be a tube on the driver side to check the oil level with an aftermarket dipstick. My Pat doesn't have that tube. According to what I have found in research a non CVT will have a plug under the battery box, however my VIN brings back that I do have CVT2 installed from the factory. I have found a tiny black plug closer to cab with a small hose leading under the radiator hoses however I don't think that's the tube I'm looking for.
The CVT fiill tube is located between the radiator and the engine on the drivers side. Unfortunately, sometimes this tube can break off.
Anyway, here's a pic of it (vertical metal tube with cap off and hose running into it):
and the tube cap looks like this:
