So i've got an interesting and crappy problem on my hand, my 4x4 likes to work when it wants to now, figures as I'm out of warranty (just ~3000kms)
Background:
I was out offroading about a week ago going through deep'ish snow (1-2feet) and up some really icy snowy hills, I was really giving the Pat a workout and it performed great. I went to fill up with gas and upon starting up the ESP/BAS !4WD lights all came on.
According to the manual when the !4WD light is on 4x4 performance is at a "reduced" level, if the light is flashing it is disabled due to overheating. In my case the light was steady on, and I was completely in FWD mode, this was odd as before i've had the light come on (Something was wedged in the T-Handle and causing it to be stuck, but even with the light on I still had AWD) Anyways I drove around for a bit, all 3 lights on nothing changed other than being on FWD and having no ESP, The ABS still worked.
I went home parked my Pat and came out a few hours later, none of the 3 lights were on anymore except the check engine light came on stayed on for a few minutes and then went out. I scanned for codes with my Scanguage and got the following:
U0114 - Lost Communication With Four-Wheel Drive Clutch Control Module
P0700 – Transmission Control System Malfunction
I cleared the codes, and the P0700 one has never come back, the U0114 keeps coming back all the time.
Now here is the weird part, other than the 4x4 not working when the light comes on, i'm not experiencing any other problems tranny related or anything, but the problem gets worse.
After the initial problem my Pat was fine for about 2 weeks and then it started acting up again. I can hear an audible "click" followed by a chime and the !4WD light comes on, then i'm back to FWD. The click i'm hearing is like an relay opening or closing, and its coming from under the dash probably around the OBDII port or so.
This problem happens multiple times at random with the light going on and off many times as i'm driving, then other times everything works as normal.
Anyone else had anything like this happen, and would the 4x4 system clutch be covered under the powertrain warranty as i'm out of the comprehensive warranty coverage.
Videos:
This was taken while sitting stationary in my drive way.
http://www.youtube.com/watch?v=XYnVzdAwPrs
Video taken while driving.
http://www.youtube.com/watch?v=21E_OGfrxyE
I just took these videos, no idea what the hell is going on, it got really bad for about 15 mins with it cutting out on and off, then it would "go away" then later come back again. I'm willing to bet there is a short in the system or something along those lines,
Yeah if it turns out to be out of warranty and alot to fix i'm just going to sell/trade it in and get something else:doh:
Background:
Videos:
