1 - 8 of 8 Posts
I have 2016 Jeep Patriot, it will turn over but will not crank. It was throwing codes for 3 sensors, replaced sensors and still will not start. Has anyone else experienced this? Could it be the starter?
2014 2.0 5-spd FWD
Welcome! If it turns over, I doubt it is the starter. Have the codes gone away after replacing the sensors? What were the sensors telling you? Maybe the sensors were fine -- just telling you what was wrong?
Discussion Starter · #3 ·
Codes were P0222, P0335, P0123, replaced o2 sensor, throttle body, checked the wiring and the ASD relay.
p0222 and p0123 are related to the throttle position sensors
p0335 is the crankshaft position sensor circuit
The common denominator appears to be the 5 volt supply from connector C2, pin 41 on the PCM.
Rectangle Slope Font Parallel Schematic
Font Screenshot Parallel Number Rectangle
p0123
Rectangle Slope Font Parallel Pattern
Font Parallel Rectangle Screenshot Number
Font Screenshot Number Parallel Document
Discussion Starter · #7 ·
I think it will be a haul to the dealership, not wanting to but at this point everything that has been done hasn't fixed it. I've got 2 awesome shade tree mechanics and it has them baffled. I had a neighbor say that if it is throwing all those codes even after fixing the problems, it could be the computer. ???????
1 - 8 of 8 Posts
