Jeep Patriot 2014 Service Manual in sections so you can download only the parts you need (PDF).
Accessories and Equipment
2014 ACCESSORIES AND EQUIPMENT Amplifier (AMP) - Electrical Diagnostics - Base
2014 ACCESSORIES AND EQUIPMENT Audio (Radio) - Electrical Diagnostics
2014 ACCESSORIES AND EQUIPMENT AudioVideoEntertainmentConnectivity - Service Information
2014 ACCESSORIES AND EQUIPMENT Body - Interior & Exterior
2014 ACCESSORIES AND EQUIPMENT Cabin Compartment Node (CCN) - Electrical Diagnostics
2014 ACCESSORIES AND EQUIPMENT ChimeBuzzerDriver Assist - Service Information
2014 ACCESSORIES AND EQUIPMENT Communication - Non-DTC Based Diagnostics
2014 ACCESSORIES AND EQUIPMENT Electronic Control Modules - Service Information
2014 ACCESSORIES AND EQUIPMENT Frame and Bumpers
2014 ACCESSORIES AND EQUIPMENT Hands Free Module (HFM) - Electrical Diagnostics
2014 ACCESSORIES AND EQUIPMENT Heated Glass - Service Information
2014 ACCESSORIES AND EQUIPMENT Heated Mirrors - Service Information
2014 ACCESSORIES AND EQUIPMENT Heated Seats - Service Information
2014 ACCESSORIES AND EQUIPMENT Horn System - Service Information
2014 ACCESSORIES AND EQUIPMENT Instrument Cluster - Service Information
2014 ACCESSORIES AND EQUIPMENT Intrusion Transceiver Module (ITM) - Electrical Diagnostics
2014 ACCESSORIES AND EQUIPMENT LampsLighting - Exterior - Service Information
2014 ACCESSORIES AND EQUIPMENT LampsLighting - Interior - Service Information
2014 ACCESSORIES AND EQUIPMENT Message Center - Service Information
2014 ACCESSORIES AND EQUIPMENT NavigationTelecommunication - Service Information
2014 ACCESSORIES AND EQUIPMENT Power Doors - Non-DTC Based Diagnostics
2014 ACCESSORIES AND EQUIPMENT Power Locks - Service Information
2014 ACCESSORIES AND EQUIPMENT Power Mirrors - Service Information
2014 ACCESSORIES AND EQUIPMENT Power Seats - Service Information
2014 ACCESSORIES AND EQUIPMENT Power Top - Service Information
2014 ACCESSORIES AND EQUIPMENT Power Windows - Non-DTC-Based Diagnostics
2014 ACCESSORIES AND EQUIPMENT Power Windows - Service Information
2014 ACCESSORIES AND EQUIPMENT Speed Control - Service Information
2014 ACCESSORIES AND EQUIPMENT Totally Integrated Power Module (TIPM) - Body Verification
2014 ACCESSORIES AND EQUIPMENT Totally Integrated Power Module (TIPM) - DTCS 2
2014 ACCESSORIES AND EQUIPMENT Totally Integrated Power Module (TIPM) - Index
2014 ACCESSORIES AND EQUIPMENT Universal Transmitter
2014 ACCESSORIES AND EQUIPMENT Vehicle Theft Security - Service Information
2014 ACCESSORIES AND EQUIPMENT Wiper System & Washer System - Service Information
2014 ACCESSORIES AND EQUIPMENT Wireless Control Module (WCM) - Electrical Diagnostics
Automatic Transmission
2014 AUTOMATIC TRANSMISSION 6F24 - Service Information
2014 AUTOMATIC TRANSMISSION CVT - Service Information
2014 AUTOMATIC TRANSMISSION CVT - Transmission Control Module (TCM) - Electrical Diagnostics
2014 AUTOMATIC TRANSMISSION Transmission Control Module (TCM) - Electrical Diagnostics, 6F24
2014 TRANSMISSION Transmission - Non-DTC Based Diagnostics
Brakes
2014 BRAKES Antilock Brake System (ABS) - Electrical Diagnostics
2014 BRAKES Antilock Brake System (ABS) - Service Information
2014 BRAKES Base - Service Information
Clutch
2014 CLUTCH Clutch System
Driveline & Axles
2014 DRIVELINEAXLES All Wheel Drive (AWD) Module - Electrical Diagnostics
2014 DRIVELINEAXLES Electronically Controlled Clutch
2014 DRIVELINEAXLES Front Half Shaft
2014 DRIVELINEAXLES Left Rear Half Shaft
2014 DRIVELINEAXLES Propeller Shaft
2014 DRIVELINEAXLES Rear Driveline Module
2014 DRIVELINEAXLES Right Rear Half Shaft
2014 TRANSFER CASE Power Transfer Unit - Service Information
Electrical
2014 ELECTRICAL Battery System - Service Information
2014 ELECTRICAL Charging - Service Information
2014 ELECTRICAL Power Distribution
2014 ELECTRICAL Special Tools
Engines
2014 ENGINE 2.0L - Service Information
2014 ENGINE 2.2L Diesel - Service Information
2014 ENGINE 2.4L - Service Information
2014 ENGINE Engine Cooling System
2014 ENGINE Exhaust System
2014 ENGINE Fuel System
2014 ENGINE Ignition System - Service Information
2014 ENGINE PERFORMANCE Driveability - Diesel - Non-DTC Based Diagnostics
2014 ENGINE PERFORMANCE Driveability - Gas - Non-DTC Based Diagnostics
2014 ENGINE PERFORMANCE Emissions Control
2.2L Diesel Electrical Diagnostics
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics DTCS 1, 2.2L (Diesel)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics DTCS 2, 2.2L (Diesel)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics DTCS 3, 2.2L (Diesel)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics Index, 2.2L (Diesel)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.2L Diesel
2.0 & 2.4L Electrical Diagnostics
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L (#1)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L (#2)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L (#3)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L (#4)
2014 ENGINE PERFORMANCE Powertrain Control Module (PCM) - Electrical Diagnostics, 2.0L & 2.4L (index)
2014 ENGINE Starting - Non-DTC Based Diagnostics
2014 ENGINE Starting - Service Information
General Information
2014 GENERAL INFORMATION Circuit Testing Procedures - Non-DTC-Based Diagnostics
2014 GENERAL INFORMATION Vehicle Quick Reference
GENERAL INFORMATION Engine Overhaul Procedures
GENERAL INFORMATION Symptom Check List Worksheets
GENERAL INFORMATION Trouble Shooting - Basic Procedures
GENERAL INFORMATION Waveforms - Injector Pattern Tutorial.pdf
GENERAL INFORMATION Wheel Alignment Theory & Operation
REMINDER INDICATOR RESET PROCEDURES
UNIFORM INSPECTION & COMMUNICATION STANDARDS 2010 - 2011 Routine Inspection Reference Guide
HVAC-Heating and Air Conditioning
2014 HVAC Heating & Air Conditioning - Electrical Diagnostics
2014 HVAC Heating & Air Conditioning - Service Information
Manual Transmissions
2014 MANUAL TRANSMISSION BG6 - Service Information
2014 MANUAL TRANSMISSION T355 - Service Information
Restraints
2014 RESTRAINTS Occupant Restraint Controller (ORC) - Electrical Diagnostics
2014 RESTRAINTS Occupant Restraint Controller (ORC) - Electrical Diagnostics - DTCS 1
2014 RESTRAINTS Occupant Restraint Controller (ORC) - Electrical Diagnostics - DTCS 2
2014 RESTRAINTS Occupant Restraint Controller (ORC) - Electrical Diagnostics - Index
2014 RESTRAINTS Service Information
Steering
2014 STEERING Steering Control Module (SCM) - Electrical Diagnostics
2014 STEERING Steering System
Suspension
2014 SUSPENSION Front Suspension & Wheel Alignment
2014 SUSPENSION JEEP WHEEL ALIGNMENT SPECIFICATIONS
2014 SUSPENSION Rear Suspension
2014 SUSPENSION Tires & Wheels - Service Information
UNIFORM INSPECTION & COMMUNICATION STANDARDS 2010 - 2011 Steering & Suspension Systems
System Wiring Diagrams
2014 SYSTEM WIRING DIAGRAMS
Brakes
Clutch
Driveline & Axles
Electrical
Engines
General Information
Restraints
Steering
Suspension
