Hey All,
I have a chicken and egg issue with my a/c. I definitely have a leak somewhere for sure. I went to put in some refrigerant with UV dye in last night to locate the leak, but my clutch will not engage any longer since there is no refrigerant in the lines, and I can't draw refrigerant into the lines without the clutch engaging.
I've looked online and apparently there is a solution of bypassing things with a paperclip into the relay, however when I look at where I think the relay is located, I can't seem to figure out which one is for the a/c compressor clutch. I'm attaching a picture and any help would be greatly appreciated
Thank you
Thank you
