So this isn't my first post but it is only my second...
My son has a 2008 Jeep Patriot we bought from a friend of mine who had just bought it but not done much to it. When we first got it, it would run, but would loose power and stall. We also had issues with the shift cable and the passenger side head light wont work (even with a new bulb). The friend I bought it from had just changed the alternator because the battery wasn't charging. Since then, we have: Changed the spark plugs, ignition coils, starter, and battery terminal connections, along with a repair (new bushing) for the shifter cable. I have inspected all the fuses and all are good. I also pulled out the TIPM and opened it and inspected it - all looked good. I cleaned all the connections with spray suitable for sensitive electronics and reinstalled the TIPM. I pulled the relay box and noticed one relay had corroded and when I attempted to pull it out the knife broke off in the relay connection. So I disconnected that relay from the box and wired it separately with a new relay outside the box. Yesterday, I also inspected and cleaned the wire two harnesses that come down out of the bottom of the TIPM
I replaced the relay that was broken off - I had to wire it in outside the box since the old relay knives were corroded into the slot in the box...
So far, I AM STILL HAVING THE SAME PROBLEMS WITH THE PATRIOT so frustrated.... The most significant problem seems to be whenever I switch on the rear wiper the interior console goes blank and the engine stalls and has no power. Any other time the car seems to start OK now and runs ok as long as I don't run that rear wiper. I purchased a computer and this is what it is showing me:
TCM (Transmission Control Module): 6 DTCs:
1/6: P0826: Up/Down Shift Switch Circuit;
2/6: P1723: Lock Up/ Select Control Circuit;
3/6: P0717: Input Shaft Speed Sensor 1 Circuit - No Signal;
4/6: P0722: Output Shaft Speed Sensor Circuit - No Signal;
5/6: P0721: Output Shaft Speed Sensor Circuit Performance;
6/6: P0526: 1) Battery System Voltage Low; 2) Battery Low; 3) Battery Low
CCN (Cabin Compartment Node): 2 DTCs:
1/2: B2374: Washer Switch Input Circuit;
2/2: U0141: Lost Communication With IPM (FCM/TIPM)
Also seeing the Electronic Throttle Control alarm on the dash light up...
I have disconnected the battery a couple times since I did a reset, so I am presuming U0141 may be the result of that and not a real issue - I will verify that. B2374 seems to point to a possible link with a short or something that maybe is related to the TCM errors caused by a common short or another relay issue maybe?? I am stumped... The wiring in this vehicle appears to be a mess.... I am going to reinspect the relay box again and also try to reset the vehicle by disconnecting the battery and shorting the two connections to discharge any power in the vehicle. These ongoing wiring issues associated with appears to be poor design/placement is quite frustrating... Seems like we fix one thing and another surfaces... Any advice or past experience with similar symptoms is greatly appreciated!!! Thanks,
