Hello all, I've started working on an interesting project, I'm trying to add bluetooth to the factory RAQ 6 disc radio that i have in my jeep. This is more of to keep track of this project incase anyone else is interested in doing this, i got inspiration from this video here. Its a different radio but the concept is the same.
Edit 8/10: I'll make a full guide on how to do this once this is complete.
As of right now, I will be wiring in this bluetooth audio receiver. My plan is to splice in power from somewhere inside the radio so the bluetooth board can shutoff when I shut off the car and not drain the battery (although I doubt it will drain THAT much). Next step is to hijack the sound output of the CD changer (if that is the case), to output the sound from the board to the radio. Doing it this way gives me the benefit of using the volume knob on the radio instead of being force to use my phone.
Currently I have the radio apart and there is only one connector that connects the CD changer portion of the radio to the main board, my job right now is to find out which pins output sound from CD changer board and which pins on the main board output power when the key is in the "on" position.
To be honest I think this is a longshot but I'm going to ask anyway just in case. Does anyone know which pins from the CD changer are the left, right and ground for the audio output? Images are attached for reference, in the second image (the one with the bunch of brown wires) that's the CD changer cable and in the other is the connector. I'm asking because finding out on my own will be a pain in the a$$ and im a bit lazy.
Thanks, ceokingcobra
