If I turn the a/c on both fans work, otherwise they won’t kick on. I changed the temp sensor, relays and finally the thermostats because I’m thinking there is too much pressure in the radiator hoses. Could the core be clogged? Bad ground?
YesYou didn't mention it specifically, but is it overheating?
Also, the fans are working, but only on a/c, is there a possibility that the fans/fan motors could be defective on medium or high settings
One way to test it is with a bi-directional scanner or an app like AlfaOBD or Jscan that can work through the bus to tell the TIPM to turn the fans on and off, and also to check for any fan related error codes.Also, the fans are working, but only on a/c, is there a possibility that the fans/fan motors could be defective on medium or high settings
Hi! If you continue to experience concerns, we suggest a dealership visit. Let us know if you need any support while there.If I turn the a/c on both fans work, otherwise they won’t kick on. I changed the temp sensor, relays and finally the thermostats because I’m thinking there is too much pressure in the radiator hoses. Could the core be clogged? Bad ground?
I only replaced one, thanks so much for the tip, if this second one that I didn’t know about works, you get the prize!Did you just change one temp sensor or both?
You may have pulled the main power relay.I did pull a relay while the car was running and when I pulled one of them the car killed, don’t know what that means
I have found fans not working in the medium or high setting is due to carbon buildup on the brass band/plate that the prong or needle (connected to the dial) makes contact with. Clean off the carbon and the fan resumes working at all speeds. You’ll have to pull the housing for the climate control center off but it’s easy.Also, the fans are working, but only on a/c, is there a possibility that the fans/fan motors could be defective on medium or high settings
