61 - 66 of 66 Posts
Deezil, have you seen this app before?
Wondering if it could help with zeroing in on problems, like a bad pump valve vs fluid/filter issues, etc.
Says it works with Jeep but Jeep trans doesn't support some of the options, like engine braking.
91070
91071
91072
What kind of sealer did you use between the transmission case halves when you put your CVT back together? I tore mine down last week to replace the belt/pulleys (trans filter was plugged full, resulting in low pressure which burned the belt)
Overall though not bad to work on at all.
Discussion Starter #64
I just used black rtv.
Did yours whine?
My new one whines like mad. But the trans works fine. Kind of weird.
Usually the CVT whine is caused by overfilling it.
61 - 66 of 66 Posts
