21 - 40 of 66 Posts
?Cool tread
My local tranny shop said,,,,,they dont get mutch of those tranny,,he sais there reliable.
But said if mine goes on my pat trail........3000$ to rebuilt it all.
Better then 6000$ for new.
But will i do it. Wen they guave me like 3500-4000$ for my pat.mmmmm
Again cool tread. They should fix those.
At work we have 2 nissan rogues,,,,we went trew 3 cvt tranny in them.
Discussion Starter #22
It’s fixed and back together. I did have one problem. The paper I used for torque specs, was wrong. And I kinda stripped one of the bearing retainer bolts. I stopped before it was 100% toast, but I’m not happy about it. I used loctite now to hope it stays.
Otherwise, it’s complete and will get installed this weekend. Fingers crossed it works!
Slide hammer got this one out
But had to grind the other one out
Harbor freight bearing remover
Reinstalling new bearings
Discussion Starter #23
185ft lbs!
Info for others
This little pin falls out. Keep an eye on it
You have to swap the gasket to the new filter
Discussion Starter #24
Reinstall went fast. Just over 3hrs from starting to install the trans to starting the motor.
Didn’t take a ton of pics, but took some video. I’ll upload the rebuild and install in a couple days.
Getting the fluid level right was a bit of a pain, but I got it. Trans works great, no more grinding. Hopefully I won’t have to work on it again! Put a few miles on it today, fun to drive. CVT trans is weird to me. Haha.
Too bad parts aren’t easier to find for it. Pretty easy to work on!
Good job and great write up and pics. This is awesome info, so thanks for sharing. I'm sure that it will come in handy for others.
Reactions: Deezil
It’s good to see you were able to replace the bearing. If anything else were to fail though in the CVT (like the Steel belt), that would have been impossible to find,no?
Discussion Starter #31
I found the steel belt on ebay believe it or not. So it is possible to replace that too! It was under $200
Now, how mechanically inclined must one be to take on a job like this would you say? If you were to give it a grade from 1-10 (being the hardest). I would like to enjoy my Jeep for many years to come, so I want to know if I would be able to attempt this if the time ever came to it.
Discussion Starter #33
There was nothing hard about it, two things that I noticed out of luck was a little pin that keeps the shift lever in place, it fell out on the bench and happened to notice it (Ill address it in the upcoming video) and on the pulley side, there is a part that rides on the pulley and has a pin that hooks to the valve body, I luckily noticed that was out...
I just went off videos on youtube, and printed off whatever manuals I could find. Ill do a closing post with videos and all my materials as soon as I can!
There really wasnt a ton of other info on doing this, so Im hoping to cover the bases to help others on it.
BUT, that said, I think if you can do the basic mechanical stuff you can do this. Transmissions seem like alot of black majic, and Im still a little new to them, this being my second one apart, its not as bad as it seems as long as you take your time and pay attention. Take ALOT of pics when you take things apart.. And lay them out in order so it goes back the same way.
1-10, Id say 2 or 3.. It was really easy, MUCH easier than a normal auto trans thats full of planetaries and clutches and plates, one way bearings, etc...
Discussion Starter #34
Part 2, part 3 is uploading...
Part 2
We open up the CVT JF011E transmission and diagnose the problem, in my case, it was a bad bearing and race, $37 part! If yours is grinding while driving, this may be the same issue. I did replace both of them on that shaft, just to be safe.
I also open up the other side to have a look at the metal push belt. Pretty weird design, but really simple and easy to work on. I point out torque specs, key things to look for, and mistakes to avoid.
If this is helpful please, let me know below! Dont forget to SUBSCRIBE!
This tranny is used in Nissans and who knows what else. Part 3 will be the installation and final drive!
Moderator
. . . and hamsters on treadmills! A conventional a/t looks like it was designed by Rube Goldberg.
Discussion Starter #37
Transmission Install 2009 Jeep Patriot CVT Automatic JF011e PT3
I really appriciate you sharing all this Deezil. I've rebuilt TF727s and TH400s, but I've never seen the insides of a CVT before. Your videos are undoubtedly informative. Thanks again!
Reactions: Deezil
Discussion Starter #40
You bet! I hope it helps someone! Ill probably search out more broken ones and fix them, these trans are soooooo easy to work on. Its a shame they dont sell parts.
21 - 40 of 66 Posts
